Submission instructions
WATERS will accept two types of submissions: regular contributions and challenge solutions.
Regular contributions
Again this year, we offer a flexible submission format.
  • Regular papers should follow the IEEE conference format (2 columns, 10 pt, single-line spacing) and should not exceed 6 pages in length.
  • Proposals for a technical presentation should consist of a one-page abstract following the IEEE conference format (2 columns, 10 pt, single-line spacing) where the title starts with “Abstract: ”. If the technical presentation concerns a tool or a benchmark, it is essential to make these available to the reviewers.
Regular contributions should be submitted by using the easychair conference management system. The system acknowledges receipt of each submission by sending an e-mail to the contact author, and it allows revision of a submission until the deadline. In order to submit a contribution, use this link:
https://easychair.org/conferences/?conf=waters2017
All submitted contributions will be reviewed by the workshop program committee. The accepted contributions will be made available online via the WATERS community forum before the workshop so that contributions can be examined prior to the event. The copyright remains with the authors.
By submitting a contribution, the authors agree and confirm that, if accepted, at least one author will register for WATERS 2017 by the special registration deadline set in the notification of acceptance, and present the contribution at the workshop in person.
Challenge solutions
Challenge solutions must describe a (possibly partial) solution to the WATERS industrial challenge and present the strengths and limitations of the used approach. Authors are strongly encouraged to implement their solution in a tool and make it available along with the submission. They will be able to present it at the interactive demo session. In addition to the proposed solution, each paper should also discuss how much time and effort was needed by the authors to (a) understand the challenge and (b) solve it. Submitted solutions should follow the rules specified for regular paper contributions in terms of length and format.
Challenge solutions should be submitted by using the easychair conference management system. The system acknowledges receipt of each submission by sending an e-mail to the contact author, and it allows revision of a submission until the deadline. In order to submit a solution, use this link:
https://easychair.org/conferences/?conf=fmtv2017
Important: The submission of challenge solutions will be in two steps.
  • Submission by the workshop submission deadline of a one-page abstract following the IEEE conference format (2 columns, 10 pt, single-line spacing)
  • Submission by the final version deadline of the full solution: a 6-page max paper in IEEE conference format (2 columns, 10 pt, single-line spacing) describing the proposed solution and a link to the associated code.
All submitted solutions will be reviewed by the industrial challenge committee. The accepted papers will be made available online via the WATERS community forum before the workshop so that contributions can be examined prior to the event. The copyright remains with the authors. Depending on the participation, a joint publication of the challenge solutions will be considered.
By submitting a solution, the authors agree and confirm that, if accepted, at least one author will register for WATERS 2017 by the special registration deadline set in the notification of acceptance, and present the solution at the workshop in person. In addition, your submission implies that you agree to participate as a reviewer to the (light-weight) evaluation of contributions submitted by others.
